Old 31-Mar-2014, 10:25 AM   #1
ATSC MH Mobile Tv
ATSC Digital Broadcast Tv is Transmitted and Received 2 ways.
1.
Standard ATSC Digital Broadcast Tv that does not cope well with movement such as trees and airplanes and other movement.
The picture/sound breaks up into blocks and sometimes goes blank.
2.
ATSC MH = ATSC Mobile Hand Held. And is also named ATSC Mobile.
ATSC MH/Mobile , has Extra Digital Information that Corrects the Disrupting Effects of Movement on the ATSC Digital Broadcast Tv Transmission and Reception.
ATSC MH/Mobile , can be received when the ATSC MH/Mobile receiver is moving or when the ATSC MH/Mobile receiver is not moving such as in a house or other buildings.
ATSC MH/Mobile is transmitted and received , Circular or Elliptical antenna polarizations.
The receiving antenna can be in varying degrees vertical and horizontal positions.
With Standard ATSC , most but not all Tv transmission and reception is with the Tv antenna in the Horizontal position/plane.
Rabbitears.info , http://www.rabbitears.info/sitemap.php , shows a list of --Standard-- ATSC Tv Stations that are Transmitting , Circular or Elliptical polarizations.
http://www.rabbitears.info/oddsanden...ization&type=C , the C is for Circular.
http://www.rabbitears.info/oddsanden...ization&type=E , the E is for Elliptical.
Here is a list and not the only listing of Digital Tv Stations that are transmitting ATSC MH/Mobile.
http://www.rabbitears.info/market.php?request=atscmph.
Here is more information ,
http://mobile500alliance.com.
http://www.dyle.tv.
Also note the ATSC MH/Mobile signal is the same as Standard ATSC , in that the Best and Most Reliable Reception happens when the Receiving Antenna is Free of Obstructions.
For the Best Reception with the receiver in a building the antenna needs to be above the roof of the building in such a manner that the roof and building are not blocking reception in the directions of the Tv transmitters.
Here are some and not all ATSC MH/Mobile Receivers.
http://www.firebird-systems.com.
http://visiontechamerica.com/site/portfolio/vt-mhc.
Please note that just because ATSC MH/Mobile receivers are made to install in a vehicle or boat does not mean the ATSC MH/Mobile must be installed in a vehicle.
The receiver can be inside of house/building and connected to a power supply.
Here are some more and not all ATSC MH/Mobile receivers.
http://www.hauppauge.com/site/products/data_aero-m.html.
http://www.mobile-dtv-viewer.com.
http://www.decontis.com.
Select ,
Mobile TV Viewer
ATSC+ATSC-MH
Last edited by teleview; 29-Aug-2014 at 8:13 AM. Reason: Clarify information and typos.
