Old 7-Nov-2012, 1:49 AM   #2
A simple reception situation.
Above the roof install a ANT751 antenna with no preamplifier in such a manner that the roof or house is not blocking reception in the directions of , north west , west , south west , south , south east , east.
Aim the ANT751 antenna at about 184 degree magnetic compass direction.
The ANT751 antenna is a little directional toward the front of the antenna and also receives good at front angles and back angles and back of the antenna.
http://www.solidsignal.com , has the ANT751 antenna with a J type antenna mount for , low dollars.
Also check , http://www.amazon.com.
____________________
For one Tv connected use No splitter. No preamplifier.
For 2 Tv's connected use a common simple 2 way splitter. No preamplifier.
_________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv set up menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
