Thank you for the quick response OTAFAN!
That was my thinking too and is why I grabbed the antenna. The small 'arms' are attached with small plastic clips that allow them to be moved but all of them are connected with a wire that zig zags along the length of both sides of the center of the antenna. It shouldn't be too difficult to repair it.
See my rabbitears info below. Getting stations has been tough and even more so since spring arrived with tree foliage. I recently increased my antenna height which has helped with reception.
https://www.rabbitears.info/searchma...tudy_id=136058
Thank you again for your help. Cheers!
