Originally Posted by ADTech
Try aiming your CM4228HD directly at the problem channel instead of trying to split some difference.
I forgot to say that I did actually try aiming the antenna at WTVW (80 degrees) but then the 3 other stations almost completely drop out. So since I record more off of the other stations, I kept it aimed in the middle.
It would be real simple if WTVW was VHF, then I could point a VHF at it and UHF at the others. But is it possible to combine 2 UHF antennas?
