Originally Posted by John Candle
Do you know how the home is wired with the coax , home run or loop?? Or combination of both home run and loop??
I am not sure what you mean by "home run or loop". Each jack has it's own run to a junction point in my basement. This is also where I ran my drop from my antenna. Currently I am trying to get antenna to just the living room. After I get a successful signal there I will consider further distribution of the signal to other rooms. Wishful thinking
