Old 18-Jul-2014, 6:59 PM   #1
pips
stacking antennas two in series, two in parallel
ok so i have built a few antennas db4 db8 sbgh ect im not really a genius on the whole ohm watt gain ect end.i am more the builder then the engineer so i come to u guys for help.i wanna build a db16 possible 8 one way 8 another or one array pointing in one direction.i have some expierience with car speakers and wiring to drop the ohm ect.i came across this wiring spec it is though that wiring the db16 this way will produce the 300 ohm.
i know the more antennas i connect it changes things so will this wiring actually produce the correct 300 ohm.
http://www.hdtvprimer.com/antennas/ganging.html
thanks for any help.and for having me.
pips is offline   Reply With Quote
