Old 4-Mar-2014, 6:33 AM   #2
A Simple reception situation.
For reception of , with 1 antenna aimed in 1 direction.
WCMU-TV , PBS.
WNEM-DT , CBS and MyNetwork.
WAQP-DT , Religion.
WWTV , CBS and WFQX - FOX.
WSMH , FOX and ZUUS Country.
WJRT , ABC and LWN Live Well Network and WeatherNation Tv.
WFQX-TV , FOX.
WBSF-DT , MyNetwork.
WDCQ-TV , PBS.
WEYI-DT , NBC and CW.
W24DL-D , Religion.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , East South East , North West.
Install a , http://www.antennacraft.net. HBU44 antenna.
Also buy the HBU44 antenna at , http://www.amazon.com.
Aim the HBU44 antenna at about 120 degree magnetic compass direction.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The aim can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
Home Depot and Lowes have 10 foot lengths , TOP RAIL , chain link fence PIPE , that makes good antenna mast , the price is low dollars.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , connection locations.
Here are some more ways to receive and record.
http://www.epvision.com.
http://www.channelmasterstore.com
Last edited by teleview; 4-Mar-2014 at 3:35 PM. Reason: Clarify information and typos.
