Thread: Setup Help
Old 3-Mar-2013, 3:41 AM   #44
BobHaskett
Originally Posted by lbo View Post
I just installed a DB4e from Antennas Direct in the attic at my mom's house, I was trying to pick up stations 40 miles away and in the same general direction. Not thinking I would pull in much, if anything especially in an attic, I managed 38 stations! I used a pre-amp but even without it I had many stations coming in......... the pre-amp helped with signal strength with the stations I was getting.
VHF was a little difficult since the DB4e is a UHF antenna. I simply made a horizontal dipole using two telescoping rabbit ears and picked up Channels 6 and 12.
Check out the DB4e, it was perfectly sized too for my moms cramped attic.
How did you make the VHF dipole?
BobHaskett is offline   Reply With Quote
