Old 26-Jul-2019, 10:27 AM   #9
Brokenspoke
FM reception would call for an all-channel antenna which includes intentional support of the low-VHF band. The longer elements at the rear of this type of antenna are what provide reception capability for real channels 2 through 6 + the FM band.
A premium option would be the Winegard HD8200U or the Channel Master Advantage-100.
The Yaesu rotor suggested by rabbit73 would be an appropriate option, especially when using a large all channel antenna.
Some folks would consider an entirely separate antenna and cable run for FM.
Thanks GroundUrMast, I had looked at that antenna but had not considered a separate antenna. I will do some research and try to make a determination on the best way to go.
As you can tell I am not very antenna knowledgeable.
Thanks again, Tony
Brokenspoke is offline   Reply With Quote
