Old 20-Mar-2014, 10:26 AM   #5
The Current Broadcast Tv Stations/Channels that are transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has receivable Tv stations/channels in all 3 Tv bands.
Aim the TERK HDTVi antenna at about 160 degree degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas.
The best location for Reliable Reception is , in/at a window or balcony door window that is to the , South ~ South East.
If a long coax running through the apartment is required to connect the antenna in/at the window to the Tv , then so be it , the reason is Reliable Reception is More Important then objections of coax running through the apartment.
If you have a balcony that faces , South West , South , South East.
The Federal Antenna Law says you can install a BroadcastTv Antenna out on an balcony or patio.
Here is the Federal Antenna Law.
http://www.fcc.gov/mb/facts/otard.html.
Hiding Tv antennas and being Discreet are good ways to have Less Reception.
Last edited by teleview; 20-Mar-2014 at 5:55 PM. Reason: Clarify information and typos.
