Old 4-Oct-2013, 6:46 PM   #4
http://www.tvfool.com/?option=com_wr...46ae1ed0a48e62.
Looking at the Current Plus Pending Applications Included Digital tvfool radar map and channel list for reception of the Digital Broadcast Tv stations/channels in the Green and Yellow reception zone.
Install a Terk HDTVi antenna (not HDTVa) antenna in/at a , window or patio/balcony door window that faces the faces the ~ South West ~.
Glass and pelxi-glass has little resistance to Broadcast Tv Reception
Aim the HDTVi antenna at about ~247~ degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If a long run of coax running through the building is required to connect the HDTVi antenna in/at the , window , patio/balcony door window , to the Tv , Then So Be It.
________________________________________
If the reception of the Digital Broadcast Tv stations/channels in the Green/Yellow reception zones is/are not reliable , then install a Winegard , LNA-100 'Boost' amplifier.
The Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
____________
http://www.solidsignal.com.
http://www.amazon.com.
__________
Last edited by teleview; 4-Oct-2013 at 7:54 PM. Reason: Clarify information and typos.
