Thread: Mounting my db8
Old 5-Dec-2018, 1:37 PM   #7
Nascarken
So true on that DB8,and way over priced to
The antennas Direct 91xg is the best ANTENNA for uhf cents that is what it is for
And the solied SIGNAL Hdb91 that has a beem with pattern of 60,is all so a good
Uhf only antenna and when using an mast mount amp like the channel master 7777
Amp with its 32BG in mass or CT state you should be able to receive BROADCASTING TOWER 80miles away day or night time in good or bad weather conditions.
And with the HDB91,with its 60with Beem if pointed right no rotor should be used??
