Old 30-Mar-2019, 10:25 PM   #16
Nascarken
Banned
Originally Posted by blackstone View Post
I ended up doing a return on the Clear Stream and ordered a CM 5020.
Several things were factors in the decision to go with this one.
The weight and size are a little smaller so I'm hoping it will handle winds a little better on the mast.
Reception angles and it states low VHF.
If Antenna Direct had a VHF antenna like that, I would have, probably, gone with them again because I think they are a decent company
You should have went with the 3020,IT'S better for the low vhf.&
Suggest you should use a channel master 7778AMP
We'll good luck let us know what happens with it when you install it.
