Old 18-Oct-2011, 12:55 PM   #9
No static at all
No static at all's Avatar
Originally Posted by Gap626 View Post
I have considered an outdoor antenna mounted to the chimney; however, my wife is not happy with this plan unless I can find one that is invisible.
The ANT-751 is nearly invisible once mounted on the roof & should work well for your situation. If distributing to more than 2 sets a Channel Master 3414 distribution amp would be a good fit.
If you must go in the attic, I would steer clear of the Winegard HD series as they are difficult to fold back up without damage. Go with one of the Antennacraft models if so.
