Originally Posted by MisterMe
GroundUrMast explained it clearly in the post that you copied. It means that the preamp will tolerate high-powered signals without saturating and will not ouput signals that are too powerful for your TV tuner to handle.
Ah... okay.. but then what Spec line item should I look for? Just that it says "high input?"
Also, I will be aiming the antenna at the low/weak stations only. So hopefully the stronger Seattle stations don't get a strong signal since I'm not pointed at their direction, so maybe this "high input" should be less of a concern.
I'll have a 2nd antenna just to get the Seattle stations, which it does just fine.
