Old 6-Feb-2013, 3:38 PM   #13
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
__________________________________
Removing the Reflector Screen allows the UHF reception loops to receive more signal at the 'back' of the antenna.
With the Reflector Screen on , the UHF reception loops receive more signal toward the front of the antenna but less at the back of the antenna.
Most reception situations , 1 aim direction will receive all the Tv stations.
However , some reception situation , antenna aiming is Experimental.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Digital Broadcast Tv tuners can develop , Digital Glitches , that are not cleared out with simple channel scans.
Do a Double Channel scan.
http://www.dtv.gov/rescan.html.
KCWX is transmitting on VHF low band channel 5 , the VHF low band channels are 2 thru 6.
The CS2 UHF channel 14 thru 51 , and with the VHF reception rods channels 7 thru 13 , and is a small antenna.
If not able to get the small CS2 with the VHF high band reception rods to receive the Tv stations.
Will need to go to a Bigger antenna for better reception of the , VHF high band channels 7 thru 13 , and VHF low band channels 2 thru 6.
And might need to go to 2 antennas.
However give the CS2 with the VHF high band reception rods , a good try first.
