Old 20-Nov-2015, 2:49 AM   #11
JimMcGowanPMCM
Do your antennas have their mast clamps at the rear of their boom(s) or at the center of mass or pressure?
Center of Mass, but its nothing more then holes drilled in the aluminum. I could drill a second set of mounting holes near the back of the antenna. I would have to get the balance close on both antennas to keep from stressing the mast but that may be ok with the T-Bar. The antennas are very light, only 4.5 lbs each. At 160 degrees I could probably keep the overlap to a single element.
JimMcGowanPMCM is offline   Reply With Quote
