Old 28-Apr-2012, 11:58 PM   #22
SVTarHeel
As of December 2011 I own an HDHR3-US... Again, I wish SiliconDust had retained separate RF inputs to the individual tuners.
I'm thinking through the cable cutting process. At this point the leading contenders are a Myth HTPC and HDHomeRun. I ran across a new-in-the-box HDHR - it's white and has 2 plugs in the back. Is this like the 1st one(s) you have? Any reason to go for new new? Or is the dual input preferable in your mind?
Do you have your Myth box up and running? My Linux experience is limited although I have poked around the Mythbuntu site a bit.
My setup is relatively simple. We currently have DirecTV (two HR24 receivers) and 98% of everything on both DVRs is watched on a Samsung LN-T4053H. (I also have a Panasonic DMR-EZ27 DVD recorder there.) Am I correct in assuming that a Myth setup can play our 2% on the other TV with a low-end computer attached to it?
I have an uninstalled DB4 antenna as well. I have some questions about that for a later date/another thread.
Thanks for any pointers or clarifications.
SVTarHeel is offline   Reply With Quote
