Old 29-Aug-2012, 8:58 PM   #2
Tv Reception.
The following is a Teleview Broadcast Tv Reception Recommendation.
Go to Radio Shack and buy a Plain Simple Non Amplified Indoor Antenna , #15-1874.
Or go to Best Buy and buy a Plain Simple Non Amplified Indoor Antenna , RCA-ANT111.
There are Many , Very Strong Easy to Receive Tv stations at your location.
Aim the indoor antenna at about 260 degree magnetic compass direction. (south west).
Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If the building is wood with wood or vinyl siding , with No metal backed insulation , then Tv reception should be very good.
If the building is , concrete , concrete blocks , cinder blocks , bricks from ground to roof , big rocks for walls , metal siding , metal roof , metal backed insulation , solar panels , Tv reception will be reduced or blocked.
To improve reception in a reduced or blocked situation put the Plain Simple Non Amplified Indoor Antenna in a , west , south west , south , facing window.
If the Tv is not at the same location as the window , use a long coax to connect the antenna to the Tv.
DO NOT connect the Tv to the cable Tv outlet.
The Plain Simple Non Amplified antenna is connected to the Tv.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
_______________________________________
