Old 28-Feb-2019, 10:40 PM   #1
ChicagoNW
Question Longer-Distance Advice?
I am delighted to join this site, and this is my first post!
Following is my reception report: http://www.tvfool.com/?option=com_wr...9038ff1d2ad6ea
Currently I am using a ClearStream 2MAX antenna with its optional reflector. Since it’s a brutal winter, I am currently using my new antenna INDOORS on the ground floor near my primary receiver. With this setup, I amazingly found a “sweet spot” where I can receive all “green” stations down through RF20, with the exception of RF12 (high-VHF) and RF24 (low-power). This suits me fine, as WBBM has a repeater on RF32 (virtual 48.3), which gives me CBS.
When the weather is nicer, I would like to install a higher-gain antenna that might give me the chance of picking up Rockford and Milwaukee. Ideally, I would prefer a single UHF/VHF antenna.
Would appreciate suggestions! After extensive research, I am torn weighing the tradeoffs of antenna size, directionality and durability for harsh winter weather. Some candidates, based on my research, might be CM-5020, CM-4228HD or Antennas Direct XG91. I realize the latter two are optimized for UHF, so VHF reception would only be a “bonus,” if possible. Open to thoughts about these and other options that might allow me to pick up adjacent markets.
Thanks!
ChicagoNW is offline   Reply With Quote
