Old 6-Feb-2017, 1:24 PM   #7
WIRELESS ENGINEER
Originally Posted by Stereocraig View Post
The 8200 will also serve as an FM antenna, but may also need a rotor and may cause watching/ listening conflicts, w/ or w/o a rotor.
yes, since the 8200u also picks up FM as well, you can then take down the existing FM antenna
you will need a preamp that passes FM so you will need
something like the channel master 7778 instead
most potential channel conflicts are below 0db noise margin so they will likely be too weak to watch
and with the high side and rear pattern nulls of the antenna, merely turning a few degrees away from possible
interference should do the trick
