Old 19-Feb-2014, 9:04 PM   #2
For reception of the , Digital Current Plus Pending Applications Included Broadcast Tv Stations/Channels in the Green reception zone and maybe some in the Yellow reception zone and most likely non in the Red reception zone.
Install a , Terk HDTVa antenna in/at a South facing window aimed at about 160 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Recommend do not install any type or kind of antenna in the attic , Reason: Is not worth the effort , the Tv stations in the Red reception zone ,
such as and not limited to ,
XHDTV-DT MyNetwork and XETV-DT The CW ,
are to Weak of signal strength and have 1 and 2 Edge Path Obstructions ,
to be received reliably in the attic.
At a Minimum , Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of reception , South West , South , South East.
Install a , http://www.channelmasterstore.com , CM4228HD antenna aimed at about 160 degree magnetic compass direction.
Install a , RCA TVPRAMP1R preamplifier.
The RCA preamplifier will be operated in the single antenna mode.
The FM radio interference trap switch will be in the , in/on , position.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Home Depot and Lowes have , Top Rail , 10 foot length , chain link fence Pipe that works well for antenna mast , the price is Low Dollars.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception.
Multi-Path Reflections Bouncing All Around.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tuners will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Channel Scan for ATSC-Digital Broadcast Tv Stations/Channels.
For better installation of a outdoor above the roof antenna.
http://www.ronard.com/909911.html
http://www.ronard.com/34424560.html
http://www.ronard.com/ychim.html
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com
Last edited by teleview; 21-Feb-2014 at 4:57 AM. Reason: Clarify information and typos.
