Old 15-Sep-2012, 9:38 PM   #2
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast tv reception.
Antenna system number 1.
For the Deltona/Orlando groups of Digital Tv stations/channels install a Winegard HD7698P antenna with a Antennas Direct CPA-19 Preamp , aimed at about 190 degree magnetic compass direction.
Here are places to buy the HFS splitters. http://www.hollandelectronics.com , http://www.solidsignal.com.
If you have a way to mount the antenna then Ok , if not then here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods5200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com.
It is best to locate the Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel from the transmitting antenna to the receiving antenna.
Do not channel scan for cable tv channels.
