Old 15-Dec-2011, 11:47 PM   #11
dodgeman1973
Originally Posted by Electron View Post
I see no other receivable NBC television station or NBC digital subchannel. . My point of view is to evaluate the situation and arrive at a answer that will most likley produce desired results. Yes it is true that WMC-DT 5 NBC is a weak signal and digital tv signals are subject to interference in the VHF low band channels of 2 thru 6. However the way I see it is that it is Better to have tried and succeeded or have tried and not succeeded then to give up before even trying. And it is best to try with the best antenna for the job like a Winegard HD7084 or Winegard HD8200U or a Channel Master CM3671.
WMC always is at about 80%. been at 95% to 100% today. thanks for your recommendations
dodgeman1973 is offline   Reply With Quote
