Old 7-Feb-2014, 8:29 PM   #4
For reception of the weaker signal strength Digital Broadcast Tv Stations /Channels to the North East and stronger signal strength Digital Broadcast Tv Stations/Channels to the South.
With 1 antenna aimed in 1 direction and no antenna rotation with a antenna rotator.
Install a , www.antennacraft.net , HD1800 All channel antenna aimed at about 47 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Here are some Above the Peak of the Roof antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com.
Home Depot and Lowes have , Top Rail , chain link fence Pipe that makes a good antenna mast , the price is low dollars.
Install a , RCA TVPRAMP1R , preamplifier.
www.amazon.com
Buy the , HFS-2D , 2 way splitter at , www.hollandelectronics.com , or , www.amazon.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice is to install the HD1800 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
