Thread: Water in Coax?
Old 14-Jan-2013, 9:43 AM   #8
Stereocraig
Originally Posted by teleview View Post
YES you can Do A Lot and Even More to protect components from the weather.
(Boots and silicone grease and boots and silicone sealer will still let the weather and water in.)
The Coax Seal Brand will keep weather and water out of the connections.
And Scotch Coax-Seal and Rubber Mastic Tape.
The Rubber Mastic Tape is Self Fusing , it fuses to it's self and what it is applied to.
It works so well at keeping the weather and rain out of connections and the bond is so strong , that the only way to get it off is cut it off.
To clarify, I probably should've said that you can never do too much.
