Old 2-Oct-2013, 11:25 PM   #35
Damon459
Cable should not be acting as an antenna. Cable should only conduct signal from the antenna to the tuner, with no signal leaking in or out along the way. Only the antenna should behave as an antenna.
This continues to make me wonder about the integrity of the connections between the coax and connectors at each end.
However, the ANT-751 is a much smaller antenna than I would specify for your situation. You may simply be receiving too weak a signal to insure reliable reception %100 of the time.
Well it you ended up being right, I missed something last night the was the cause, our local thermal inversions. I didn't know they would actually cause signal issues. For all my connections I used a kit from DataShark purchased at home depot. http://www.homedepot.com/p/Paladin-D...5#.UkydDijWp7Q
Damon459 is offline   Reply With Quote
