Old 13-Aug-2012, 9:57 PM   #3
Tv Reception.
The following is Teleview recommendation for broadcast Tv reception.
Above the roof install a Winegard HD7698P antenna aimed at about 118 degree magnetic compass direction.
Do not connect any other antennas to the HD7698P antenna system.
The HD7698P antenna system stands alone , as a antenna system.
No preamplifier.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
Here is how aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
As always , trees and tree leaves do a real fine job reducing and blocking Tv reception and so do buildings and other obstructions.
It is best to locate the antenna at a location that has the least amount to no amount of any type or kind of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
