Your location has receivable Digital Tv stations/channels in All 3 Tv bands of ,
UHF band channels 14 thru 51.
The HBU55 Is Not Designed to receive , VHF low band channels 2 thru 6.
-->The HD7084P is designed to receive ALL the Digital Broadcast Tv channels <--.
Here are 2 VHF low band channels the HD7084P is designed to receive.
WIWN VHF low band channel 05 .
http://en.wikipedia.org/wiki/WIWN. In the Milwaukee direction.
And
WOCK-CD VHF low band channel 04.
http://en.wikipedia.org/wiki/WOCK-CD , America One ,
http://www.americaone.com. In the Chicago direction.
__________________________________________________
Tv antenna rotators are Not channel surfing friendly , must wait for antenna to rotate and not every one in the house will agree on the direction the antenna is aimed.
For your reception situation I recommend install the HD7084P antenna system for reception of Chicago Tv stations.
As a test to see if you will like to receive the Milwaukee Stations , by hand , aim the HD7084P antenna at about 17 degree magnetic compass direction.
If you choose to receive the Milwaukee stations install a second HD7084P antenna system that is set up the same as the antenna system for the Chicago Tv stations.
The Chicago and Milwaukee Tv antennas systems will be Separate antenna systems all the way to the locations of the Tv's and Will Not be connected together on to one coax.
The Separate antenna systems will be connected to a Remote control A/B antenna coax switch at each Tv location.
http://www.mcmelectronics.com , #32-4425 , or ,
http://www.radioshack.com , #15-1968.
Remote control A/B antenna switching Is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing at each Tv location in the house.
