Old 10-Jan-2020, 9:30 PM   #2
In an effort to get a more complete idea of what signals will be like with the completed repack I ran a rabbitears report for you (based on an estimate of your location) https://rabbitears.info/searchmap.ph...study_id=43290
It looks as if you should expect to have little difficulty with OTA reception. You might be successful with an indoor antenna but home construction may interfere. I'd opt for an all channel antenna such as the Channel Master CM-2018 mounted on a roof or wall with a clear view towards the west. (243 degrees magnetic)
