Old 9-Nov-2019, 12:32 AM   #1
8bit
Go higher or go better?
I purchased a medium sized antenna from HHGregg before they went out of business and I pulled my satellite dish from the roof and installed my antenna on its pole. The antenna is about 10 feet off the ground. Where I live we are kind of in a hole if you will and there are tall trees surrounding our home.
I currently use an RCA TVPRAMP1R Preamplifier for Outdoor Antenna and a powered splitter in my attic. The antenna I believe is an RCA ANT751R.
I can currently get ABC, CBS, NBC & Fox but Fox and especially CBS would break up often. I'm interested in only these major networks.
My question is, should I go higher up with an extension pole with my current antenna or purchase a good antenna like a Winegard HD7698P Platinum Series.
Also, is it possible to install two antenna facing different directions but combine them so a motor is not necessary? With the correction position I can get all channels but CBS still suffers. I'm just trying to cover all the bases. Please suggest an antenna or antennas. I would greatly appreciate the help!
If anyone would like me to generate a different report, please let me know.
http://www.tvfool.com/?option=com_wr...9038259b65825a
Many thanks!
8bit is offline   Reply With Quote
