Old 28-Jun-2014, 1:48 PM   #16
Stereocraig
The problem is, the tuners in TVs and boxes can vary a lot in sensitivity, and ability to handle multipath problems, from model to model. What I do, is to compare two tuners side-by-side by using a variable attenuator and a splitter to find out which tuner drops out last as I reduce the signal.
Code:
                                  tuner #1
antenna > attenuator > splitter >
                                  tuner #2
With my equipment, my SONY KDL22L5000 has about the same sensitivity as my Apex DT502 and Centronics ZAT502HD boxes. My later SONY KDL22BX320 is about 2 dB more sensitive.
My point, exactly!
Why should I shell out dough, to compare a TV's performance?
