Old 3-Apr-2013, 3:18 AM   #2
Here is the Federal Antenna Law that states Clearly that the Hoa has No Say what the size of the Broadcast Tv reception antenna is for reliable reception.
The Federal Antenna Law says Yes you can install a Broadcast Tv antenna of any size Above The Roof so as to have Reliable Reception.
The Federal Antenna Law Protects You and Millions of other People.
The Federal Antenna Law makes Null and Void -->the people hiding behind the rules and regulations that they make up - and call them selfs , Hoa's/Aho's , housing coven-nuts , dead restricted housing , cities , counties , states , and any and all types and kinds of antenna haters.
http://www.fcc.gov/mb/facts/otard.html.
________________________________________________
To have a shot at Reliable Reception , of the Green and Yellow reception zones of the tvfool radar report and channel list of Digital Broadcast Tv stations/channels , NBC , CBS , ABC , PBS , , FOX , CW , MyNetwork , Me-Tv , This Tv , Country Network , and Etc. , that are of All Directions at your reception location.
Install a ANT751 antenna Above The Roof aimed at about 265 degree magnetic compass direction.
In such a manner that the roof and house are not blocking reception of All
Directions.
The ANT751 comes with a , J type antenna mount.
Install a Antennas Direct CPA-19 preamp.
For 3 Tv's connected use a , HFS-3D , 3way splitter.
Buy the HFS splitters at , http://www.soldsignal.com , or , http://www.hollandelectronics.com.
http://www.solidsignal.com , http://www.amazon.com.
As always , attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Signal Attenuation , electric/electronic interference , multi-path/reflecting-signals bouncing all around.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path/reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
