Old 2-Apr-2011, 9:20 PM   #21
The ZAT970 can connect to your TV with RCA Video/L/R cable(s). If your TV has the inputs for that type connection, you should expect a slightly better quality signal when viewing digital sources. You could leave the coax connected between the ZAT970 and the TV to support analog reception, but it needs to be in serviceable condition.
JC is correct to wonder if there is a problem with the coax between the ZAT970 and TV. Poor shielding (caused by a faulty connector for example) may allow the strong RF in your area to interfere. Use of the V/L/R connection would eliminate the RF link between the ZAT970 and your TV, thus eliminating a complex process that may be interfered with.
