Old 30-Mar-2011, 8:09 PM   #7
Dave Loudin
Originally Posted by PhayenK View Post
Its mounted at a slight angle, but it looks like its supposed to be a little.
No, you usually mount that antenna with the screen perpendicular to ground. The first thing I'd try is changing the tilt angle back to exactly vertical before anything else. You should then try raising/lowering the antenna in place before searching out a new location.
