Thread: Antenna Newbie
Old 12-Mar-2011, 6:31 AM   #6
dsmguy7
Thank you all for your help.
@Towerguy and Coco-You are right. I didn't realize those antennas were so big. What about the Winegard HD7696P? It's about 9 ft. long. Would that work ok? I also would rather not use a preamp unless I have to. I also would rather leave the antenna up in a storm unless I have to. Any way to make it more sturdy?
@Groundurmast--10-4 and thank you. HD7696P? Any recomendations on coverter boxes? As I mentioned I have 2 old tvs so no hd capability and if I buy new tvs later they would have the tuners built in, so I don't need anything special; right? I am not a sports fan so any other reasons for me to get the MS stations? Wow, 30 ft. does make a huge difference. Don't think that I can justify any higher though. http://www.tvfool.com/?option=com_wr...597908dbceb009 Also which azimuth should I point the antenna to (weakest channel, split the difference, etc.)?
@JohnCandle--Thanks for the advice and I am shying away from that antenna.
dsmguy7 is offline   Reply With Quote
