Old 14-Oct-2023, 10:41 PM   #6
OTAFAN
Before you finally check out of this thread, jimmylittleman, please provide the link to the post you mentioned regarding the inserter burnt out issue.
I think this would be very helpful to others who probably will encounter some of the same issues you had.
This way the forum can direct them to the post you found. Otherwise, they'll have to spend a lot of time searching as you did.
FWIW, here's a link to a CM power inserter. I don't know if this is similar to the one you used:
https://www.channelmaster.com/produc...ers-cm-7777xpi
Thanks for keeping the forum updated!
All the best.....
