Old 25-Sep-2021, 6:41 PM   #2
Originally Posted by maypo View Post
Getting ready to put up a new but older (assembled and sitting the barn for 2 years) DB8. I am smack dab in the middle (but slightly closer to rochester) between Buffalo and Rochester......I got to thinking that i could get another DB8 or maybe a DB4 and mount them back to back, would be less "rotoring"......Can someone chime in on the downsides of this choice.
Hello, maypo.
How would you combine the two antennas? Or, would you have a switch to select which antenna you want to use?
Please do a signal report for your location. The TVFool reports are no longer very accurate. Here is a sample report from rabbitears.info for Le Roy:
https://www.rabbitears.info/searchma...tudy_id=357787
You can do a report for your location at this site (I use coordinates from Google maps):
