Old 7-Mar-2021, 12:43 AM   #8
Originally Posted by Reaper7534 View Post
I cannot even sniff a signal from WXII with a directional yagi. I'm currenly about 5 feet off the ground but will be extending it another 15 ft this weekend, don't know if it will make a difference
Antennas Direct is correct; there is a hill in the signal path.
Using different software to confirm the problem:
This is an image of the signal report you posted at AVS; it's more accurate for your location:
The only chance you have for WXII is a separate antenna like the HDB91X aimed at WXII.
