Thank you for the reply. The AVS Forum link was helpful...the most recent post there indicates that the only WSB signal right now is the one from Atlanta.
That seems to be reflected in the RabbitEars report also. The only WSB transmitter showing up is channel 32 from Atlanta. Meanwhile, two of the three channels that should be by far the strongest are listed as off-air.
https://www.rabbitears.info/searchma...tudy_id=190553
I see that the database for the TVFool reports was last updated pre-repacking...that's actually quite helpful for comparison if it's still accurate as of how things stood in 2017.
(Running it again for my location produced this report:
https://www.tvfool.com/modeling/?id=903872156194f3
Back then I was able to pick up the likes of WANN-CD and WTBS-LD on a good day...haven't yet had a sniff of them since I got set up with my new preamp.)
