Old 25-Jun-2020, 11:05 PM   #4
Tim
Originally Posted by derf View Post
Hi,
Thanks for the reply.
RabbitEar report:
https://www.rabbitears.info/searchma...tudy_id=112047
The two channels I'm having trouble with are the yellow highlighted channels.
Have this antenna:
https://www.amazon.com/Antennas-Dire.../dp/B004H1NDLG
This amp/splitter:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
About 20 feet from either TV to the amp/splitter. About 5 feet from antenna to amp/splitter.
Well, to start with, the antenna you have is designed for UHF channels only. WAFB and WBRZ are VHF-Hi channels. You need a separate element for the antenna to pick up VHF-Hi. See the picture.
You can order a kit to add that to your antenna.
https://www.amazon.com/Antennas-Dire...CMG/ref=sr_1_3
There are other things, too, that could be the problem, but the first step would be to have the correct antenna.
