Old 4-Jun-2020, 2:08 AM   #4
Tim
Originally Posted by agios11 View Post
Thanks. A couple people on Facebook also recommended that antenna. I am seriously considering it since it looks like it may improve my reception a bit. However, when I contacted Wineguard asking about what I would need to buy to install it, they said that antenna would not pull in low uhf channels. I may get it from somewhere that takes returns and return it if I can't get all my channels. Then I can just buy the antenna I already have since it has worked well.
The Winegard antenna won't pull in Low VHF channels--do you have any stations in your area broadcasting on channels 3, 4, 5 or 6?
It looks like you are in the Sevierville area...do you want to receive the stations out of Knoxville???
Also, it would be helpful if you could provide a RabbitEars signal report which is much more up-to-date than TV Fool. https://www.rabbitears.info/searchmap.php
