Old 28-Feb-2020, 1:35 AM   #7
Tim
Originally Posted by mikmaze View Post
yeah, figured I would find the worst spot.. this was with only 30 ant height, only just figured out setting new height. doesn't seem to help much unless you get crazy and are over 100 feet up!
. https://www.rabbitears.info/searchma...study_id=63955
Yeah, your location shows you are behind some pretty good size hills...that will definitely cut down on the TV signal available. On your RabbitEars report you can click on the 'Transmitter Distance (Miles)' figure for each station and see what the terrain looks like between you and the transmitter. Here is an example for WSYT in Syracuse.
