Old 11-Jan-2020, 4:50 PM   #3
The ANT-751 has enough gain for the Houston stations unless it’s installed in a poor location. However, there are some Beaumont stations that are receivable with a bidirectional UHF antenna on the roof or in a favorable attic location. The Antennas Direct 2MAX should get UHF from both Beaumont and Houston, but might not get the VHF stations from Houston. (KHOU, KUHT, and KTRK). If the VHF reception isn’t perfect, couple your existing ANT-751 to the 2MAX using a UVSJ splitter/joiner.
Note that many of these stations are running low power while there is antenna work on their towers.
