You're correct, there is some potential for co-channel interference... However it looks as if there is enough difference in signal levels (20 dB or more ) that it's reasonable to hope for reception of WFSB.
To be successful, you may need to mount an antenna outdoors, above tree top level. I would also expect to need a full sized UHF antenna or combination UHF/High-VHF. The terrain between you and Hartford forces you to use a substantially larger antenna than you would need if there was a clear line of sight.
the Winegard HD7698P would be a full size combo to consider. One could also combine the 2018 with an Antennas Direct DB8e... Using a UHF/VHF combiner, the DB8E would connect to the UHF port and the 2018 to the VHF port.
Reason: added comment re. line of sight
