Old 13-Dec-2019, 12:04 AM   #18
BigHenry
Well, I installed the new balun CM-94444 this afternoon. Because the new balun leads mount on top and fall on either side of the CM-5030 antenna frame, I felt I should not shorten the balun leads. I re-aimed the antenna using the same bearing where I detected good signals previously. Unfortunately, I don't receive the 7's and 10's but still get the 15's and 38's. I suppose the CM-7777V3 medium gain pre-amp will be the next thing we try.
BigHenry is offline   Reply With Quote
