Old 15-Nov-2019, 1:33 AM   #5
Originally Posted by tuktuk View Post
o No preamp or amp of any type.
o Only one connection to the antenna, which is a TV tuner card (hauppauge WinTV-quadHD) in a desktop.
Final, quick question, if my cable length from antenna to the desktop more than say 50 or 60 ft, do I need an amp or a preamp of any type?
Thanks much.
Use the Hauppauge signal monitor app to tell you the SNR of a signal to see if any changes made reception better. The SNR should be at least 16 dB; the higher, the better.
http://www.hauppauge.com/pages/suppo...l_monitor.html
The Uncorrectable Errors should be zero.
