Old 24-Oct-2019, 11:14 PM   #38
ckwsp101_tv
Just curious, what value did you end up with for horizontal spacing? What was the value you were did vertical stacking?
Do you think the values would be good for stacking Stellar Labs 30-2476, which I believe has a similar configuration as the Y-10-7-13's ?
My current horizontal distance is 100 inches.
I need longer feed lines to increase distance.
I did not find a best vertical stacking distance as i had limited space on mast.
i used 30 inches.
I used Silicondust signal quality measurement to confirm distances doing right thing.
My situation atypical. Likely I will need another mount and location to place 2nd y10-7-13 longer term. Right now using saw house mount.
ckwsp101_tv is offline   Reply With Quote
