Old 29-Sep-2019, 8:26 PM   #10
Originally Posted by tuffones View Post
I' m aiming the 91xg to Roanoke Va and the Mediasonic HW to the south towers. I m picking up all the channels from the south BUT the Charlotte and Raleigh only early in the morning. I can not get a solid signal afternoon, or evening.
Channel Master CM3410 PCT with Channel Master LTE Filter for 3G signals
Winegard Combiner CC7870
NOTE. months ago I used to have the 91xg south and the Y5713 aiming to Roanoke Va and picking those channels in the morning.
The link to your estimated rabbitears.info report again (I don't have your exact address):
https://www.rabbitears.info/searchma...study_id=11931
an extract from that report:
Using the Winegard CC-7870 Combiner is a lot like using a splitter in reverse as a combiner.
It doesn't always work because when the same signals from each antenna reach the combining point, they will interfere with each other if they are not in phase (arrive at the same instant).
If you don't get all the signals when combined that you had when the two antennas were separate, that method of combining doesn't work at your location.
As a test, I suggest you aim just the 91XG at Roanoke without the combiner to see what you get.
Are there any trees or other objects in the signal path from the North?
