Old 23-Aug-2019, 11:45 PM   #2
WFSB was co-channel with WCBS on UHF 33 causing much of southern CT and parts of the Hudson valley .to suffer the loss of either or both stations.
I'd suspect you're experiencing a temporary reprieve due to WCBS having to run off an auxiliary antenna at lower power while the permanent system at 1WTC is completed. Once they are able to go to full power, their co-channel interference may well be enough to knock out WFSB again. Post re-pack, they're now both on UHF 36. Doh!
If Tower Guy drops by, he can probably provide more background since he worked "next door".
